In the Support Download area is now available the "Installer StarGo 6.1.0 No Flip Beta".
This firmware version is based on the 6.2.0 and the only difference is that the “Meridian Flip Disabled” option comes activated as default. This option is active even when used with Skysafari, also without the PC.
Note for this beta version:
- In order to having the correct mount behavior movement, the first GoTo must be performed to the Eastern side of the Meridian.
- In case of using with the PC StarGo Software, the “Meridian Flip Disabled” option can be switched off, coming back to the standard mode.
- The “Meridian Flip Disabled” option will not be lost when the power is turned off.
If you only want to test we suggest to rename the previous stargo software folder before to install this version (you can follow this tutorial:
www.avalon-instruments.com/component/all...ade-to-5-2-3-version)
Here the link for the download.
www.avalon-instruments.com/support/file/...o-6-1-0-no-flip-beta
Clear skies
