Question Stargo BT with T-REX Drives
  • PhilRob
24 Aug 2021 04:58 - 24 Aug 2021 05:50 #646 by PhilRob
Stargo BT with T-REX Drives was created by PhilRob
I have a Stargo Bluetooth system with the T-REX Drive Kit.
I have installed the stepper motors but the stepper motors seem to continually bind randomly when slewing/tracking no matter what tension I set on the belts.
Is there a proper installation guide and recommended tensioning for this system?
Thanks
PS Just a quick update: The T-REX is a Japanese Alt-Az mount. I have just finished adjusting and re-meshing the worms so the mount runs very smoothly in push to or manual guided modes.
Last edit: 24 Aug 2021 05:50 by PhilRob. Reason: Updated about mount
25 Aug 2021 00:55 #649 by jg
Replied by jg on topic Stargo BT with T-REX Drives
Hi Phil,
I'm sure you've thought of this, but perhaps double check you have the correct mcf selected in the Stargo. I have the Avalon steppers installed on an old EQ mount and they work perfectly - a vast improvement on the motors I used to have on it.
  • PhilRob
25 Aug 2021 02:16 #650 by PhilRob
Replied by PhilRob on topic Stargo BT with T-REX Drives
Hi jg,
Yes. I do have the correct Configuration Profile for the mount.
The issue seems to be either physical tensioning of the belt drives, which I have spent extensive time adjusting or the stepper motors themselves under load.
Unfortunately I have no guidance/manual on the belt drive tensioning and alignment....although alignment wise there is not much room for movement/change there anyway.
Phil
25 Aug 2021 20:43 #652 by jg
Hi Phil,
Yes, there is not much movement to tension the belt, but I’ve not needed much - tight, but definitely not maximum works for me. Have you tried running motors without OTA load and even without belts - do they still stall? If so, then sounds like something wrong with motors.
25 Aug 2021 20:45 #653 by jg
Also, what V power supply are you using?
  • PhilRob
27 Aug 2021 01:01 #654 by PhilRob
Hi I am using the original Stargo Powersupply which is switchable to multiple Voltages....Set at 15V Cheers Phil
