Question INDI 2.x Support - Timeline?
  • Planet30
  • Premium Member
  • Premium Member
11 Nov 2023 09:05 #1220 by Planet30
INDI 2.x Support - Timeline? was created by Planet30
Thank you for updating STARGO2 to INDI 1.9.7. earlier this year. This helped for some drivers.
The new drivers are, however, all developed and designed for the new INDI 2.x.
Any plans and timeline for updating to this major release?
17 Nov 2023 15:22 #1226 by Stefano82
Replied by Stefano82 on topic INDI 2.x Support - Timeline?
We inform you that we have almost completed the test of the internal StarGo2 INDI version that should be ready for the next INDI release (2.0.5?).
Within this release you will find the StarGo2 driver (it will be called "AvalonUD") that can be selected from the INDI list driver, so, it can be used from external devices as Asiair or others.
  • Planet30
  • Premium Member
  • Premium Member
18 Nov 2023 13:16 - 18 Nov 2023 13:26 #1228 by Planet30
Replied by Planet30 on topic INDI 2.x Support - Timeline?
Thank you, Stefano!
This is excellent news!
Last edit: 18 Nov 2023 13:26 by Planet30.
07 Dec 2023 16:57 - 07 Dec 2023 16:58 #1262 by Stefano82
We are glad to inform you that, within the last 2.0.5 INDI server release it is available the AvalonUD driver, you can find it in the Avalon Instruments folder.
We already tested it with Ubuntu and Stellarmate and works properly, obviously using it in local server mode. In this case we suggest to uncheck the automatic connect, then set the proper I.P. address before the connection.
At this point you will also find it inside the ASIAIR mount driver list, as soon as they will update their firmware to the last 2.0.5 version.
Last edit: 07 Dec 2023 16:58 by Stefano82.
  • Planet30
  • Premium Member
  • Premium Member
07 Dec 2023 18:34 - 07 Dec 2023 19:11 #1264 by Planet30
Thank you, Stefano!
Excellent news!
I assume, you mean this driver:
github.com/indilib/indi-3rdparty/tree/master/indi-avalonud
I will check with ZWO, if they could use this driver...
Last edit: 07 Dec 2023 19:11 by Planet30.
  • Planet30
  • Premium Member
  • Premium Member
07 Dec 2023 18:49 #1265 by Planet30
... how do we update the StarGO2 to INDI 2.0.5? Please, advice.
