Solved Balancing my M-Uno
18 May 2021 09:08 - 18 May 2021 09:31 #544 by Louis
Balancing my M-Uno was created by Louis
I cannot balance in RA this configuration which is less than 15 kg
The mount is positioned on the B1 balance configuration
Thanks for your help
Louis Joly
Last edit: 18 May 2021 09:31 by Louis.
18 May 2021 19:51 #545 by jg
Replied by jg on topic Balancing my M-Uno
Have you considered mounting the refractor on a dual dec clamp? It would at least reduce the need for so many CWs...and might help with overall balancing.
18 May 2021 20:23 #546 by Louis
Replied by Louis on topic Balancing my M-Uno
This is indeed the solution that I am considering
04 Jun 2021 09:32 - 04 Jun 2021 10:18 #566 by Louis
A priori balancing in DEC should go
On the other hand, impossible to balance in RA, the brake does not manage to retain the whole
The set of instruments and accessories must be less than 17 kg
On the counterweight bar I have 4 weights of 1.4 kg and on the small bar I have 0.55 kg
I am thinking of making a longer bar to add weight, is that possible?
thank you for your help
Louis Joly
Last edit: 04 Jun 2021 10:18 by Louis.
04 Jun 2021 14:42 #567 by Stefano82
Replied by Stefano82 on topic Balancing my M-Uno
How much it is the unbalacing amount on the RA axis?
Of course you can make a longer bar in order to add weight and find your fine balancing but, as other users already suggested, another solution could be to place the refractor in the bottom side of the DEC arm in Dual Dec configuration?.
In this way you could at the same time reduce the overall and the use of counterweights.
04 Jun 2021 14:59 #568 by Louis
Thank you for your reply
My M-Uno dates from 2017, how do you carry out the assembly you recommend?
Thank you for your help
Louis Joly
