- Thank you received: 0
Guillaume wrote: My guiding is between 0.6" and 1" RMS with large peaks sometimes 2" away.
This was not an issue with my old setup which had 1.38"/pix sampling but is an issue now with my new setup which has 0.7"/pix sampling.
It may be related to the OAG which has a substantial higher definition now compared to before and may be way more sensitive to seeing.
Someone had good result with zfilter algo inside PHD2 (the only time I tried was catastrophic so I went back to lowpass2.
Note: I use the parameters recommended by Avalon with an OAG 1000mm focal length.
