I got COM port problems and StarGo shutdown etc. when switching from M Uno to a M Zero with the same PC
On the W10 PC there is the newest StarGo software installed. Until now it was used to control a M Zero BT (on COM 2). Meanwhile a got a M Uno and loaded the specific mount configuration file which worked fine. M Uno on COM 6.
For a different setup I need the M Zero and started StarGo with the mount connected (only the M Zero.....). Then several crashes of StarGo occured and I was repeatedly ask to "choose COM port" etc..
What is the suggested sequence to change between two mounts using the same PC?
thanks for tipps!
