Before to use the mount with SkySafari, we suggest to make a test with the mount connected to a PC/Laptop, then performing some GoTo with the help of planetary software such as Carte du Ciel, Stellarium etc.. it will be possible to check the the mount slew direction.
In case of one of both axis wrong direction slew, you can follow the instructions explained in the following topic in order to allow the mount to slew in the correct direction.
www.avalon-instruments.com/forum/install...kit-and-ra-dec-setup
After you are sure that the mount slew in the correct direction, you can watch the following tutorial to control your mount with SkySafari.
www.avalon-instruments.com/component/sps...stargo-and-skysafari
Please try in this way and let us know about it.
