Question Problems goto.
12 Oct 2021 07:56 #724 by Paul
Problems goto. was created by Paul
Hey,
When I bought my first M zero a few years ago, the software didn't need any other software to do a star alignment.
Now with the new software with my new M zero you need a second software for a star alignment (skysafari ,carte du ciel)
Is it not possible to run the old software on the stargo? Because my star alignment now I have a lot of problems with it, I use sky Safari and I can't find my objects via the goto.
Regards Paul
12 Oct 2021 17:37 #726 by JethroXP
Replied by JethroXP on topic Problems goto.
Are you only observing visual, or do you have a camera attached? With a camera you should be able to plate solve without need to perform star alignment.
13 Oct 2021 17:52 #727 by Paul
Replied by Paul on topic Problems goto.
I'll give that a try but will it work with a dslr?
What I do want to know about Avalon is that I can reinstall the old software.
Regards Paul
17 Oct 2021 00:46 #733 by JethroXP
Yes, the camera doesn't make much difference, as long as the software you use with it supports plate solving. I use N.I.N.A. for imaging, and plate solving.
21 Oct 2021 16:51 #738 by Palmi81
Replied by Palmi81 on topic Problems goto.
Ciao a tutti
una domanda su questa impostazione? come funziona e cosa devo fare?
Non ricevo la procedura a 3 o più stelle. poco visibile; solo verso sud
si prega di inserire le immagini che verrò con.
utilizzare una Nikon Z6 non modificata e una fotocamera Guider ASI 120 MM-S.
saluta
ale
22 Oct 2021 14:24 #739 by JethroXP
You don’t need Polaris to polar align, nor do you need any manual Star alignment. If you have a view to the south and a camera on your telescope you can use PHD2 drift alignment for polar aligning and you can use plate solving in NINA, or SharpCap, or any other Astro imaging software to align your telescope with the sky.
