Question STARGO2 Pro with N.I.N.A. and ASCOM?
  • Planet30
  • Premium Member
  • Premium Member
30 Oct 2021 16:21 - 30 Oct 2021 17:05 #759 by Planet30
STARGO2 Pro with N.I.N.A. and ASCOM? was created by Planet30
I am very new to ASCOM. I can use Carte Du Ciel on my Mac and access the new mount controller by accessing/logging into the StarGO2 ASCOM server.
On Windows and after installing ASCOM and NINA, I cannot find the STARGO2 mount in the ASCOM chooser. How do I get NINA to connect to the mount via its IP address?
Thank you for your help.
Last edit: 30 Oct 2021 17:05 by Planet30.
30 Oct 2021 20:15 #761 by JethroXP
Replied by JethroXP on topic STARGO2 Pro with N.I.N.A. and ASCOM?
30 Oct 2021 20:18 #762 by JethroXP
Sorry, my text got dropped from the images I just shared.
You have to enable Alpaca Discovery in the ASCOM Chooser. Click the word Alpaca, and then click to enable discovery. Doing that should add a green rectangle to Alpaca Discovery and allow you to see StarGo2 Telescope in the selection drop down menu.
  • Planet30
  • Premium Member
  • Premium Member
30 Oct 2021 22:34 - 30 Oct 2021 22:35 #763 by Planet30
Replied by Planet30 on topic STARGO2 Pro with N.I.N.A. and ASCOM?
Thank you so much! This worked!
First the little "light" was always red. I had to change the security settings in Windows to make the PC discoverable in the network, which was disabled by default.
Now All I need is good weather :-)
Progress!
Last edit: 30 Oct 2021 22:35 by Planet30.
