Solved StarGO2 Not Saving Location Information - Latitude and Longitude
  • cmscs5532
11 Nov 2021 13:48 - 19 Nov 2021 09:37 #777 by cmscs5532
When I change the Longitude and Latitude on the StarGO2 webpage it will not save the change and reverts back to Avalon in Italy. The web app does not hold the IP Addressing either, the IP's are shown on the StarGO2 unit and are saved upon reboots and after a power cycle they just won't show on the webpage. Has anyone had this issue and is there a solution for both issues?
Last edit: 19 Nov 2021 09:37 by Stefano82.
11 Nov 2021 16:15 #778 by Stefano82
The problem with the Location Coordinates setting may be connected with the browser cache, just clear it, normally with Ctrl+Shift+Canc ( which is your browser?).
  • cmscs5532
11 Nov 2021 19:06 #779 by cmscs5532
Hello and thank you,
I have cleared the browser cache on Chrome and Edge on my desktop, Chrome on the StarGO2 Raspberry pi as well and it still won't save the Coordinates. I just set the local date, time, timezone, keyboard, and WiFi country the on the StarGO2 and will see if that helps.
11 Nov 2021 19:35 #780 by JethroXP
If you export the config file you can see where that data lives. I presume you could confirm if the new values are set, and if not, edit the file and upload it.
  • cmscs5532
12 Nov 2021 13:53 #783 by cmscs5532
Thank you JethroXP I will give it a go today.
  • zubajohn
16 Nov 2021 05:02 #786 by zubajohn
Hello. I solved this problem by changing the coordinates 2 digits at a time, quickly tabbing out after entering 2 digits. That seems to work for me.
