Hi Peter
By reading your workflow explained in this post, it seems that you perform a Sync Home Position after an Unpark. Is this right?
Please note that the Sync Home Position is not required after the Unparkm since, as described in the StarGo User Manual page 33:
"Using the Park function enables the mount to be switched off and restarted, even after many days, without losing the sky alignment."
So after the unpark the mount is already aligned with the sky and you can immediately start GoTo.
Your workflow can be even quicker and easy and may be performed as follow, removing the unecessary Sync Home Positiom:
Unpark -> start tracking -> GoTo
Furthermore, for fixed location setup it may be helpful the use of the "Realign Absolute Position" option. This feature allow to store in memory the pointing error offset and use it for future sessions even in case of setup power off.
The procedure to use this feature is explained at the following link:
www.avalon-instruments.com/support-2/tro...eature-in-the-stargo
