First of all, unless you are using the N.I.N.A. Version 1.10 HF3 (in this case you can keep using the StarGo 656 B2), we suggest to upgrade to the latest installer available, the Install StarGo 7.0.0 B1 downloadable at the following link:
www.avalon-instruments.com/support-2/sup...y/2-software-and-app
After the software/Ascom driver installation you should upgrade the Firmware as well.
In order to work properly the software suite should work with all its componentes upgraded as follow:
StarGo Ver. 7.0.0
Firmware Ver. 7.0.0
Ascom Driver V. 7.0.0.29
You can check if the configuration is correct by comparing the above informations with the StarGo Software System TAB after the software/ASCOM driver/firmware upgrade.
Try in this way and let us know about it.
