Solved NINA Park fail - updated ASCOM driver 7.1.26. or 7.1.2.5?
17 Nov 2023 13:15 #1224 by Stefano82
Replied by Stefano82 on topic NINA Park fail
Has been released on our support page the 6.4.0 SP7 installer that fix the wrong Alt/Az coordinates reading and management bug.
In our test this version fix the N.I.N.A park issue as well.
The following user(s) said Thank You: Samuel
22 Nov 2023 14:19 - 22 Nov 2023 14:21 #1233 by toriqo
Replied by toriqo on topic NINA Park fail
i have this version for several months now and for sure it doesn't fix the nina park issue. that's how i ended on this thread, using 6.4.0 sp7 not reporting the parking/home positions properly
Last edit: 22 Nov 2023 14:21 by toriqo. Reason: added screenshot
27 Nov 2023 10:33 #1240 by toriqo
the new updated driver, 7.1.2.6 which i just got today works. solves home slewing/parking/unparking reporting and nina doesn't have any issue anymore, solves the alt/az coordinates, those being correctly reported by the driver as well.
thank you
28 Nov 2023 12:50 #1242 by Stefano82
The Avalon ASCOM Driver 7.1.2.6 can be downloaded from the Support page area at the link below (to access is required to have an enabled account).
www.avalon-instruments.com/support-2/sup...y/2-software-and-app
It fix the Home Position losing after unpark behaviour.
This driver is for the StarGo.exe V. 7.0.8, Firmware 6.4.0
The update just require to run this exe. No Firmware/StarGo.exe update are required.
The Avalon Ascom Driver 7.1.2.6 will automatically overwrite the previous version
04 Dec 2023 13:38 - 04 Dec 2023 13:42 #1256 by Peter_S
@ Stefano:
 is the 7.1.2.6 provided on the support page  really the .6?
when opening the properties of the installer it shows 7.1.2.5:
Last edit: 04 Dec 2023 13:42 by Peter_S. Reason: screenshot 3
05 Dec 2023 15:23 - 05 Dec 2023 15:24 #1257 by Stefano82
We confirm that the driver provided is the 7.1.2.6.
The 7.1.2.5 was just a typo error in the label properties and now has been fixed.
So, the driver installer with the correct label properties has been already uploaded in the support area.
Last edit: 05 Dec 2023 15:24 by Stefano82.
The following user(s) said Thank You: Peter_S
