Solved How to explicit delete an existing sky model on stargo
  • zbidi
07 May 2020 05:52 - 26 Jun 2020 15:09 #265 by zbidi
Hi
Is there a possibility to explicit delete an existing (previous) sky model on stargo?
I was playing around. If I use multistar alignment the manual says that every sync is used to improve the sky model.
Every night I have to setup the whole thing new. In such a case the sky model from the day before is not accurate.
I use a LINEAR.
Many thanks for a short answer
Stefan
Last edit: 26 Jun 2020 15:09 by Stefano82.
11 May 2020 15:35 #273 by Stefano82
Hi Stefan
There is no need to explicit delete any previous sky model.
Every time you switch on the StarGo for a new session, the software doesn't keep anything in memory as long as you don't explicitly upload an existing file, saved and stored on your pc.
The following user(s) said Thank You: zbidi
  • zbidi
14 May 2020 10:47 #280 by zbidi
Thanks for the answer.
So I have to switch off and on StarGo.
My best regards
Stefan
