Question StarGo with HS motor for Losmandy G11 was not working
07 Sep 2020 08:03 #401 by Stefano82
Hi
At the following link you can find the latest StarGo User Manual download page
www.avalon-instruments.com/support-2/sup...ser-manual-rev-4-1-2
Please read it carefully and let us know if something is not enough clear.
30 Sep 2020 09:49 #411 by NGC
Once I installed the new driver, it worked fine.
However, when I tried to use it tonight, it seems to have broken down again.
As a symptom, I set StarGO for G11 for the time being, but it doesn't work again. With the handle controller, the motor can only rotate in one direction, both right ascension and declination. Is it out of order?
02 Oct 2020 13:19 #412 by Stefano82
Hi
In order to understand if it is only a keypad issue, did you try to move the mount by using the StarGo software directional buttons?
In this way the motor can rotate in both directions? When you use a planetary software, the mount slew correctly?
Please let us know about it.
