Question M-Due Won't Track - RA shows "Upper Limit Hit"
  • JethroXP
05 Sep 2022 23:24 - 06 Sep 2022 01:24 #1032 by JethroXP
Replied by JethroXP on topic M-Due Won't Track - RA shows "Upper Limit Hit"
Well I've watched it long enough to realize that it is moving, so the readings from the display on RA, DEC, Az, and Alt are accurate, however it's reporting that it is still. This is very confusing.
Last edit: 06 Sep 2022 01:24 by JethroXP.
06 Sep 2022 11:54 #1033 by Stefano82
Replied by Stefano82 on topic M-Due Won't Track - RA shows "Upper Limit Hit"
In order to restore the starting position, point the DEC axis toward the north (see page 17 M-due user Manual) and perform a Sync Home Position with the WebApp or directly on the StarGo2 LCD.
  • JethroXP
07 Sep 2022 02:22 #1036 by JethroXP
Hi Stefano, I've tried that multiple times, from the WebApp and the LCD screen. It doesn't appear to the change the behavior. As soon as I slew using the webapp the status reports Upper Limit Hit.
  • JethroXP
08 Sep 2022 14:34 #1038 by JethroXP
Hey Stefano, any other ideas on what I can try to resolve this? The mount is currently unusable because as soon as I slew it thinks the upper limit has been hit. Can I zero out the limits in the configuration?
09 Sep 2022 07:34 #1039 by Stefano82
Hi Jason
We are working on this to see what's happened, in the meanwhile you can work with the Encoders disabled by choosing a mount configuration file without the final "E".
We will come back to you as soon as we have news about it.
  • JethroXP
12 Sep 2022 17:16 #1043 by JethroXP
Thanks Stefano, that seems to work, though it requires that I plate solve and sync after powering off the mount. Looking forward to getting this fixed, I forgot how useful those encoders are until I didn't have access to them anymore.
