Solved M-Uno Stiff DEC axis
31 Mar 2023 10:26 #1145 by Phil
M-Uno Stiff DEC axis was created by Phil
I purchased a pre-owned M-Uno and notice that the DEC axis, when rotated, has areas where there is some stiction.  I've not tried imaging with the mount yet but wonder if the needle bearings may need to be replaced.  Or, if there is some other adjustment for this.
Thanks,
-Phil
05 Apr 2023 08:44 - 06 Apr 2023 07:37 #1146 by Stefano82
Replied by Stefano82 on topic M-Uno Stiff DEC axis
A stiff point in the DEC axis with the clutch released is something that shouldn't affect at all the mount performance.
Please consider that when the clutch is engaged the stiff point become inconsistent because the DEC flange get engaged with the axis, in this status they rotate together.
Last edit: 06 Apr 2023 07:37 by Stefano82.
07 Apr 2023 08:42 #1149 by Planet30
Replied by Planet30 on topic M-Uno Stiff DEC axis
Hi. My M-UNO is now about two years old and shows this behavior occasionally. It depends a little bit on outside temperatures.
This worried me a bit, too.
Guiding is still perfect. I have typically rms values between 0.7” and 1” with my RC10 and an OAG with PHD2.
