Hi. I've just got my M-Zero that I bought 2nd hand and I've been having some issues with it, but I think I have everything sorted now except for one thing.
It appears that the mount is tracking slightly slow, as a result, I can't plate solve targets, because the stars appear as small lines, not round points..
After talking with the mounts previous owner, it looks like I have the wrong configuration file loaded, however, I wonder if its possible to know 100% what configuration file I should run.
The mount is an M-Zero, but there are so many configuration file options and gear ratio options in the stargo software for the M-Zero.
Configuration file and Gear Ratio Options are:
M-Zero-EQ
M-Zero-HQE
M-Zero-LHQ
M-Zero-OBS
M-Zero-AZ
I'm quite sure my mount is not the OBS, nor the LHQ, as they both look considerably different to my mount, and I'm not running in Alt/Az mode, so it's either HQE or EQ for the gear ratios. I had been running on HQE, as that is the model that best matches my mount on the website, however the previous owner was running EQ gear ratios. I've not seen any information for the EQ model anywhere, and searching the forum did not seem to yield any results either.
Is there a way to know based on the mount serial number or some other information, which is correct?
Thanks for your assistance.
Alex.
