Solved Stargo wifi connection
10 May 2022 12:15 - 15 Jun 2022 14:29 #937 by Stefano82
Replied by Stefano82 on topic Stargo wifi connection
Hi Tom!
By connecting the StarGo to the EAGLE via Wifi, even with a single WiFi connection between the two devices, you should be already able to use PHD2, Carte du Ciel, SGP etc…
The USB cable is suggested in order to have a more reliable and stable connection.
In case you have a different configuration just let us know and we will see how we can better suggest you.
Thanks for the feedback about Windows 11. In our tests everything worked fine but we’ll take a deeper inspection to see if we can find some issue with this new operative system version while upgrading the StarGo firmware.
Last edit: 15 Jun 2022 14:29 by Stefano82.
