Loved Slew & Center in NINA
09 Mar 2022 15:43 #885 by Schaefer
Replied by Schaefer on topic Slew & Center in NINA
Hi Stephan,
glad you found this thread...
In fact I mentioned that issue in several other threads in this forum already and I do not understand why no reaction from Avalon happens.
The latest Beta version of the StarGo driver was released last May, which is about 10 months ago. I immediately gave feedback after the release that it introduced this new bug. Nothing happened since then.
@Stefano82: May be you can give an update on that issue please? Do you need more information to reproduce it?
Best regards,
17 Mar 2022 17:48 #894 by Olivier31
Replied by Olivier31 on topic Slew & Center in NINA
I'm also interested by a fix !
I've set up some sort of workaround in N.I.NA ( increasing the number of plate solving attempt , added several tempo between actions ...) ,but I'm loosing precious time .
Thank you for your support
Olivier
23 Mar 2022 16:54 #898 by Stefano82
Replied by Stefano82 on topic Slew & Center in NINA
We inform you that has been released the Install StarGo 7.0.0 B1 at the following link:
www.avalon-instruments.com/support-2/sup...y/2-software-and-app
This version comes with the new mounts configuration file (EVO-zero, Linear HQ, M-uno HQ) and with the Avalon ASCOM driver 7.0.0 suitable for the N.I.N.A Version 2.0 BETA.
Feedback are welcome
24 Mar 2022 01:58 #899 by ryanfraser
Replied by ryanfraser on topic Slew & Center in NINA
Stefano, does this version fix the problems with slewing in SGP as well?
24 Mar 2022 22:18 #903 by stephan
Replied by stephan on topic Slew & Center in NINA
Hi!
I tried the new driver tonight but ran into problems with slewing. I tried slewing to a target from within NINAs framing assistant. The scope was slewing, settling at some coordinates but then started slewing again. It seems it ended up in an endless loop.
I am using NINA 2.0 nightly build #55
Any ideas? Any more information needed from my side?
Best wishes
25 Mar 2022 10:21 #906 by Stefano82
In order to see if the installation upgraded correctly the Avalon ASCOM driver as well, please provide us the StarGo.exe SYSTEM tab screenshot.
We tested the latest StarGo installer:
StarGo Ver. 7.0.0
Firmware Ver. 7.0.0
Ascom Driver V. 7.0.0.29
With the NINA 2.0 BETA055
and we could see that the mount behave as it should do:
Slew to target, settling, exposure, slew again.
We performed this test indoor in laboratory so we couldn't plate solve, but if works in this way it can be assumed that everything should be fine even plate solving.
If your configuration match with the one mentioned above and still doesn't work please provide us a small video to see the behaviour, maybe we can notice something that can be changed.
