Question !!! REPOSTED !!! EKOS Polar Alignment Tool no longer work with my Avalon Zero
23 Sep 2022 12:57 - 23 Sep 2022 12:58 #1062 by Planet30
Hello Stefano,
Thank you for your reply.
In the case of the StarGO2 it is clearly an issue with the mount control and not with EKOS.
I did tests as requested by Jasem, which prove that East and West is mixed up. I tried it with both the INDI and the ASCOM driver. Either the mix-up is in the drivers or in the FW.
Please, refer to my posts here and on the INDI forum on the same topic.
Last edit: 23 Sep 2022 12:58 by Planet30.
24 Sep 2022 08:09 #1063 by kodo
Hi Stefano!
Thanks for replying!
FYI I decided to install v6.2.0 a couple of weeks ago but the erratic behavior remains unfortunately.
24 Sep 2022 14:30 #1064 by sterne-jaeger
I can confirm this problem. The root cause is that the firmware does not report properly RA changes when the mount is in the home position.
Slew to a (high) position close to the meridian and do the polar alignment from there. Be careful, if you are west of the meridian, use a WEST motion (and vice versa).
HTH
Wolfgang
ONTC 10"F4 + epsilon-160 + FSQ-85 + FS-60CB + Dobson Factory 12" + TSA-120 | Avalon Linear + M-zero | ASI 2600mm pro + ASI 6200mm pro | INDI/KStars on Intel NUC and Raspberry Pi 4
26 Sep 2022 12:05 #1068 by kodo
Hi Wolfgang!
Many thanks for chiming in! Do you (or Stefano) have an E.T.A. when this will be fixed?
26 Sep 2022 15:49 - 26 Sep 2022 15:50 #1069 by Planet30
Hi Wolfgang,
Thank you for this inside! Could this be valid/applicable for the StarGO2 Pro as well?
Last edit: 26 Sep 2022 15:50 by Planet30.
26 Sep 2022 15:54 - 26 Sep 2022 15:59 #1070 by Planet30
In the EKOS-PAA when using the SG2P, I usually remain on the eastern side of the meridian facing East with DEC between 0 and +10°. I then go either from East to West or from West to East in 30° (=2h RA) steps by manually changing the RA in the mount/telescope control in EKOS.
The automatic slewing does not work here. I know it is maybe not the same bug/issue as with the classical SG, but it might be related.
And then there is this issue:
indilib.org/forum/ekos/10407-polar-align....html?start=36#84507
Which also seems to be related, but is much more severe, since it requires a full reboot of the SG2P's RPi4.
Last edit: 26 Sep 2022 15:59 by Planet30. Reason: Adding more related info.
