Has anyone used the Linear mount with the Baader Steel Drive affixed to a FeatherTouch focuser? Does the Steel Drive motor plug directly into the Linear Mount and then is controlled with the Linear Mount hand controller, as described in the User Manual? Or do you need to use the Baader control box in between? Any help appreciated! I don't want to spend the money for the Steel Drive if it will not work well with my focuser.
