Solved M-due hitting mount limits and change in pointing model
  • daserpey
22 Mar 2023 23:29 #1138 by daserpey
Hello. I am having some issues with Avalon M-Due may be you could help me out. The problem it seems to be related with the mount limits. It appears that the mount does not recognize the minus symbol and in the  dec lower limit which is -45 it reads +45 and when it hits it loses the mount pointing model and it thinks actually that it is at -45. I decided to put it at -90 and if it reads +90 it s the same that the high limit. Anyway I think it is still hitting limits in RA or Dec in the north side and loosing the pointing model. Is there a way to deactivate the mount limits? Best regards
28 Mar 2023 13:49 - 06 Apr 2023 07:36 #1143 by Stefano82
This is issue was related to an older version of the StarGo2 Pro firmware.
We already sent you via mail a version that fix the reported behaviour.
Last edit: 06 Apr 2023 07:36 by Stefano82.
  • daserpey
05 Apr 2023 18:23 #1147 by daserpey
Tha Avalon team was very reactive in sending the needed firmware to fix this issue.
