Hello Stefano,
If I balance the telescope perfectly in the area I want to image, let’s say Vulpecula, mount is on the eastern side, facing southward, then:
- if I move the telescope in DEC axis only to the northern side, it will be heavier in front.
- if I move the telescope to the western side, telescope facing north, it will be heavier on the back and if I move it to the southern side only DEC axis, it will be heavier in front. Also, usually R.A. is not perfectly balanced anymore.
Movement is not violent, the telescope finds the equilibrium at some point, it won't hit the tripod.
So, if the balance is not “guilty” for spikes in guiding, could it be seeing? It is usually not great at my site, but could such sudden turbulence in the air mass cause 2” - 3” spikes in guiding?
Thank you for responding!
Jure
