Hi!
Yester after one ours in the night, i could report, that my old problems with the wifi are back. I dont know why, but i cant connect to my mount. And there are two problems:
The first problem is with the succestfull connected wifi. When t ry to connect in SkySafari, there is an error:
Translated:
Connection error
SkaSafari Pro cannot establish a wireless connection to the telescope.
If you are using a serial Bluetooth adapter, check that it is turned on and connected to the Android device.
If you are using WLAN, check that you are using the correct WLAN and have entered the correct IP address.
My second problem after this upper mentioned problem is:
Yesterday after aprox. 15 minutes, i cant connect to the wifi. I find the network in the wifi list, but i cant connect to it. See at this video here:
www.dropbox.com/s/kqtacrdg4wqre3i/VID_20200327_210632.mp4?dl=0
There are also two problems: 1. When i press on the StarGo networkt to connect, it shows for less the one second "connecting..." and then nothing happens. No error or something else. 2. The StarGo network disappears when i press on it. After some time it will appear. Reallsy strange, but you can see it at the video.
Please note the following information:
-> I am standing right next to the mount.
-> I have not changed any settings in StarGo.
-> I have not changed any settings in SkySafari.
-> I have not changed any settings in my Android devices.
-> With all these settings it worked again and again before. But sometimes I had these problems even before that. These problems keep coming back.
-> I tried with my Galaxy S9+ smartphone and my Huawei MediaPad M3 Lite tablet. With the tablet I could not even connect.
-> I took StarGo off the power and restarted it again. Several times.
-> I restarted my Android devices.
-> I have deleted the StarGo connection on both devices and tried to reconnect.
-> I have the blue version of the M-Zero HD
I would be pleased if we could find the cause of this problems. This is a big problem for me, because I bought this mount not only because of the transportability but also because of the easy operation by Wifi and SkySafari. But this Wifi connection does not work reliably for me.
Thank you!
