Dear
Before to start the session did you perform the Sync Home Position as shown in the following tutorial? (even if the tutorial has been made with an M-zero, the procedure is the same for any mount controlled by the StarGo)
www.avalon-instruments.com/forum/install...530-and-losmandy-g11
It is also important to set the correct Observatory Location in the ALIGN panel that should match with the settings of the planetary software used.
Wich is your workflow to set the Park Position? The correct procedure is:
- Choose the position where the mount should be parked and click on the “Set Park” button.
- At the end of the session click on the “Park” button. In this way the mount will slew to the selected park position and, in the next mount usage, the mount will remember the Home Position synced.
More information about it at page 33 of the StarGo User Manual
If you are using a G11 mount with the StarGo HS motor kit you should select the Losmandy_HS.mcf file.
More information about how to find the correct value for the mount gear ratio at the following forum topic
The latest StarGo Software/Firmware is the StarGO 6.2.0 SP3 that can be dowloaded at the following webpage after being logged in with your user credentials.
www.avalon-instruments.com/support-2/sup...ler-stargo-6-2-0-sp3
Please try in this way and let us know about it
