Solved meridian flip fallito con sgp
02 Feb 2022 19:28 #870 by igor.lamberti
Replied by igor.lamberti on topic meridian flip fallito con sgp
Novità sul rilascio di un bug fix riguardo a questa problematica ?
grazie
03 Feb 2022 10:55 #872 by Stefano82
Replied by Stefano82 on topic meridian flip fallito con sgp
As previously described in this thread, for SGP users is suggested the SP6 version, since from our tests and from feedback coming by many users, it work properly with the above mentioned software.
For users that face this Meridian Flip failure even using SGP with StarGo 620 SP& please note that, due to particular SGP configuration, it is required to set the Meridian Flip at least 5/10 minutes after crossing the Meridian.
The StarGo 6.5.6 version it is suggested for N.I.N.A. users, since this version fixed the Slewing during plate solve bug with this software.
04 Feb 2022 15:30 #874 by Schaefer
Replied by Schaefer on topic meridian flip fallito con sgp
Stefano82 wrote: Hi all
I already wrote to the forum and also directly via email to you that this is actually not the case. At least not, when you are using the current Beta version of NINA 2.0. The 'fix' in 656 introduced a new bug, which leads to slewing errors again. You fixed the synchronous slewing command but broke the asynchronous slewing command, which is used by NINA and may be other software as well.
It might be ok to use the 656 version in the 1.x version of NINA (which most likely nobody uses anymore) But I can only recommend using 620SP6 when you are running the recent NINA 2.0 version which has tons of improvements since 1.x.
04 Feb 2022 15:41 #875 by Schaefer
See also here:
www.avalon-instruments.com/forum/welcome...-slew-center-in-nina
and here, in the original thread where we discussed it the first time:
www.avalon-instruments.com/forum/install...f-a-goto?start=6#552
31 Mar 2022 08:04 - 31 Mar 2022 08:04 #915 by Stefano82
It has been published a reply about this issue at the following forum topic link:
www.avalon-instruments.com/forum/welcome...nter-in-nina?start=6
Last edit: 31 Mar 2022 08:04 by Stefano82.
