Solved meridian flip fallito con sgp
  • Marco Marulli
  • Marco Marulli's Avatar Topic Author
09 Sep 2021 07:52 #668 by Marco Marulli
Replied by Marco Marulli on topic meridian flip fallito con sgp
ciao Stefano il problema persiste anche con la versione StarGo 6.2.0. SP6.
25 Sep 2021 14:17 - 25 Sep 2021 14:19 #684 by RetoH
Replied by RetoH on topic meridian flip fallito con sgp
Hi Stefano, I have the same problem with my Linear mount and SGP. Do you know a date until when this will be fixed? The StarGo 6.2.0. SP6 fix is also not working...
Last edit: 25 Sep 2021 14:19 by RetoH.
14 Oct 2021 13:46 - 14 Oct 2021 13:47 #728 by ryanfraser
Replied by ryanfraser on topic meridian flip fallito con sgp
This thread has been open for a couple of months, so I am wondering if the fix may be available soon?
For further debugging: I can confirm that a similar problem occurs when using PHD2's Drift Align tool. in the tool, I can slew to a location if it is located on the same side of pier, or if starting from the home position. If I set RA/DEC to slew to the opposite horizon to drift align (other side of pier), the mount does not move. I noticed this behaviour for the first time last night, using the latest firmware & 656B2 Driver.
Last edit: 14 Oct 2021 13:47 by ryanfraser. Reason: clarification
07 Nov 2021 20:28 #770 by Michel
Replied by Michel on topic meridian flip fallito con sgp
I am having the same problem as well with my Linear and SGP. Are there any solutions aside from rolling back the firmware to 6.2?
08 Nov 2021 21:00 #772 by ryanfraser
Yes, an update would be most welcome for many of us. @Stefano82 is there any progress?
As a further debugging update, a "centre here" in SGP while at the meridian will not trigger a flip, but a "Slew here" will successfully cause a flip. I"m not sure which method SGP uses to initiate the auto flip, however.
08 Nov 2021 21:27 #773 by JethroXP
Replied by JethroXP on topic meridian flip fallito con sgp
while it seems that official responses on these forums can be hit or miss, I've had good and timely responses from Stefano and Luciano via their This email address is being protected from spambots. You need JavaScript enabled to view it. address. I'd recommend giving that a try, and then posting back here to update the thread with their response to help others.
