After ten evenings of using my new m-zero mount with SkySafari without problem, I can no longer connect to SkySafari with the wifi connection.
The wifi connection works (with Android and IOS) but skysafari does not connect to the stargo module. I have checked all the settings and these seem to be correct.
When I am connected to the stargo wifi network, I can see 2 IP addresses : 192.168.1.12 (my ipad) and 192.168.1.1 (the stargo module ?), but no 10.0.0.1 address.
If I go to the 192.168.1.1 address in a browser, I can see "Microchip" configuration page ??
I have test the "StarGO_Tools.exe" program, the connection to the stargo is ok (via USB) but it can't read the wifi information.
I reinstalled the firmware, try to use 192.168.1.1 and/or 10.0.0.1 address in skysafari,
but the problem is still there. Do you have a solution ? Hardware or Software problem ?
Thanks,
Luc.
