Have the following:
- Avalon Zero Obs with StarGo (tried all FW:s)
- Pegasus Ultimate PowerBox v2
- RPi 4B with running v2.0.4 of Astroberry
- RPi GPS Hat (Adafruit)
- QHY 5 CCD Guider
- Atik Horizon II
- SSD storage
Like my earlier (and others) post my Avalon behaves erratic with the EKOS Polar Alignment Tool. Goto using plate solving works like a charm every time but the PAT is, as I said, very erratic. Some nights it "will just work" other, like last night, it's a lie to get it to work and I have to resort to PHD2 procedures for polar alignment (not bad but I want to perform everything using EKOS). Again, I'm not sure whether this is an Avalon FW issue, Indilib driver or whatever but it is starting to get annoying. First I thought that there could be some interference going on between the USB-cables (I know it's far fetched but you get crazy after a while) but have ruled that out unless I've had six (6) bogus USB 2/3 cables which is not very likely.
The symptom looks like this:
1. I place my mount with everything attached and started pointing to the NCP (I've synced my home-position and set the parking position beforehand)
2. I enter the EKOS PAT and start the procedure
3. The CCD takes an image
4. The mount starts to move west
5. I wait for the mount to perform a 30 degree RA move but it fails to stop and continues - I've noticed that the RA coordinate for the mount is not updated on the screen while the mount slews
6. I stop the procedure
So, pleeeease, if there's somebody out there who knows of a solution to this, pleeeease don't keep me in the shadows...
MANY thanks in advance!!!!!!!
