I wonder if this is an artefact of the alignment model in the mount. There are inherently two ways to slew a mount (generically - not just Avalon). One is by activating the motor e.g via handset or virtual handset. The motor runs while the button is pressed and stops when it is released. The other is via a goto command. With the goto command the process is automated within the controller which speeds up and slows down the motors and even makes final small movements to remove backlash. Also, the goto takes into account the alignment model so that after you align the mount (e.g. by platesolving and syncing) your gotos are accurate. Now for Asiair to rotate the mount 60 degrees it can really only do this with a goto since it would not know the slew speed of the mount. So it would add/subtract 4 hours of RA and keep dec the same then do the goto. This creates two problems. The big one is if the alignment model is a long way out, so the goto could go wildly off. Also, the mount would slew in both RA and Dec instead of dec only and this would also adversely affect the alignment algorithm even if it was not so far off. I found this out when writing the SPA module in PHD2. When I automated the slew of the mount using a goto it was moving in both RA and Dec.
