Solved Cant start StarGO 6.2.0 SP1
  • Dane
  • Dane's Avatar Topic Author
16 Mar 2020 18:15 #187 by Dane
Replied by Dane on topic Cant start StarGO 6.2.0 SP1
Hi Stefano
I have the Samsung Galaxy S9 Plus. And yes, i restartet thee StarGo and also the smartphone.
Today, i have the idea i record a video in my smarthpone, to show this as a movie. I do no changes,but today, it dondt shows a error message. I can connect to the mount, but with a new problem. I recordet it, and you can also see in the clip my settings for the telesope. My new problem is the much longer time to connect to the mount. You see it in the video, it needs one minute to connect.
www.dropbox.com/s/3s0xnf6w1apup29/20200316_185747.mp4?dl=0
Have you any idea for a solution for my problem?
Thank you!
_________________
17 Mar 2020 08:24 - 17 Mar 2020 08:24 #188 by Stefano82
Replied by Stefano82 on topic Cant start StarGO 6.2.0 SP1
Hi Dane
The much longer time to connect to the mount depend on the Set time & Location setting activated.
I saw in your video that the option “Datum & Zeiten einstellen” is activated.
The function of that option is explained at page 63 of the StarGo User Manual.
Also other users spoke about this SkySafari function on this topic in our forum
www.avalon-instruments.com/forum/welcome...-wifi-client?start=6
When the Site & Location checkbox is activated, Skysafari send, during the connection with the StarGo, the data about the time and the location in order to update the internal StarGo location.
This option requires exactly 60 seconds, so it is important to do this procedure only in case the mount has been moved to a new location.
But soon after the connection has been done, I suggest to uncheck it and leave it always unchecked because the StarGO keep in memory the Location also after the shutdown.
You will see that by disabling that option the connection will takes only few seconds.
Last edit: 17 Mar 2020 08:24 by Stefano82.
  • Dane
19 Mar 2020 14:50 - 25 Sep 2020 13:24 #190 by Dane
Hi Stefano, yes thats right! This problem is solved! Thank you so much!
_________________
Last edit: 25 Sep 2020 13:24 by Stefano82.
